Compilazione kde 3.5.8
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
niente dando solo make restituisce sempre lo stesso errore comunque per sicurezza posto lo slackbuild :
#!/bin/sh
CWD=`pwd`
TMP=/tmp
PKG=$TMP/package-kdebase
# Set the config option variables if they are not already set:
if [ -r ../KDE.options ]; then
  . ../KDE.options
fi
# The global options may be overridden here (if needed):
if [ -r ./local.options ]; then
  . ./local.options
fi
rm -rf $PKG
mkdir -p $PKG/usr
# Avoid a version number in .la files:
if [ -d /usr/lib/qt ]; then
  QTDIR=/usr/lib/qt
fi
cd $TMP
echo "Building kdebase-$VERSION.tar.bz2..."
tar xjvf $CWD/kdebase-$VERSION.tar.bz2 || exit 1
cd kdebase-$VERSION || exit 1
chown -R root:root .
CFLAGS=$CPUOPT \
CXXFLAGS=$CPUOPT \
./configure \
  --prefix=/usr \
  --sysconfdir=/etc/kde \
  --with-shadow \
  --with-xinerama \
  --disable-debug \
  --program-prefix="" \
  --program-suffix="" \
  --build=$TARGET-slackware-linux
make  || exit 1
make install DESTDIR=$PKG
# Move the KDM files someplace FHS compliant:
mkdir -p $PKG/etc/kde
mv $PKG/usr/share/config/kdm $PKG/etc/kde
( cd $PKG/usr/share/config ; ln -sf ../../../etc/kde/kdm . )
### !!! KLUDGE ALERT !!! ###
### CAUSES ARTS TO NOT USE REALTIME PRIORITY BY DEFAULT, WORKING AROUND A LOGOUT HANG ###
### THIS SHOULD BE RECONSIDERED WITH EACH KDEBASE RELEASE! ###
cat $CWD/kludge/kcmartsrc > $PKG/usr/share/config/kcmartsrc
mkdir -p $PKG/usr/doc/kdebase-$VERSION
cp -a \
  AUTHORS COPYING INSTALL README kdebase.lsm \
mkdir -p $PKG/etc/X11/xinit $PKG/etc/profile.d
cat $CWD/xinit/xinitrc.kde > $PKG/etc/X11/xinit/xinitrc.kde
cat $CWD/profile.d/kde.sh > $PKG/etc/profile.d/kde.sh
cat $CWD/profile.d/kde.csh > $PKG/etc/profile.d/kde.csh
chmod 755 $PKG/etc/X11/xinit/xinitrc.kde $PKG/etc/profile.d/kde.sh $PKG/etc/profile.d/kde.csh
# Change the konsole defaults to look like the real Linux console:
cat $CWD/config/konsolerc > $PKG/usr/share/config/konsolerc
chmod 644 $PKG/usr/share/config/konsolerc
# Make konsole a login shell by default:
cat $CWD/config/konsole.desktop > $PKG/usr/share/applications/kde/konsole.desktop
chmod 644 $PKG/usr/share/applications/kde/konsole.desktop
# set sane defaults for antialiasing:
if [ ! -e $PKG/usr/share/config/kdeglobals ]; then
  cat $CWD/config/kdeglobals > $PKG/usr/share/config/kdeglobals
  chmod 644 $PKG/usr/share/config/kdeglobals
else
  # This might be fixed or unsafe.  Better check it out...
  echo
  echo "BAILOUT: kdeglobals already exists.  Check to see if anti-aliased"
  echo "         fonts work out-of-the-box now..."
  echo
  exit 1
fi
# Setup config files for KDM:
$PKG/usr/bin/genkdmconf --no-old --no-old-scripts --no-backup --in $PKG/usr/share/config/kdm
# Not allowing root to login at the console is just plain silly.  If they have physical access to
# the machine, what's the point of trying to stop this?  Even the kdmrc file says this is supposed
# to be the default.
cat $PKG/usr/share/config/kdm/kdmrc | perl -pi -e 's|AllowRootLogin=false|AllowRootLogin=true|' > $PKG/usr/share/config/kdm/kdmrc.new
rm -f $PKG/usr/share/config/kdm/kdmrc
cp -a $PKG/usr/share/config/kdm/Xsession $PKG/usr/share/config/kdm/Xsession.orig
cat $CWD/config/Xsession > $PKG/usr/share/config/kdm/Xsession
mv $PKG/usr/share/config/kdm/backgroundrc $PKG/usr/share/config/kdm/backgroundrc.new
mkdir -p $PKG/install
zcat $CWD/doinst.sh.gz > $PKG/install/doinst.sh
( cd $PKG
  find . | xargs file | grep "executable" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
  find . | xargs file | grep "shared object" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
if [ -d $PKG/usr/man ]; then
  gzip -9 $PKG/usr/man/man?/*
fi
cd $PKG
makepkg -l y -c n ../kdebase-$VERSION-$ARCH-$BUILD.tgz
Forse ho qualche problema nei pacchetti installati???
Dani
Desktop: gnome
Distribuzione: arch
Messaggio da Dani »
Hai messo kdelibs 3.5.8 ?
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
Dani ha scritto:Hai messo kdelibs 3.5.8 ?
Devo installarlo prima di compilare kdebase??Perchè non l'ho messo....
EDIT Ho installato kdelibs3.5.8 compilato da me... ora compila!!! :D Se riesco a compilare tutto kde dato che ho usato gli slackbuild di pat potrei metterlo a disposizione di tutti!Non so se è possibile su slacky.eu ....non dispongo di nessuno spazio web!
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
mi mancano ormai solo kdebindings e arts e poi kde 3.5.8 è completamente pacchettizzato.L'unico problema è che kdebindings mi da che mi dà il seguente problema:
Making all in qt
make[6]: Entering directory `/tmp/kdebindings-3.5.8/qtjava/javalib/org/kde/qt'
CLASSPATH=../../..:./../../..:$CLASSPATH  -d ../../..  -classpath ./../../..  QtUtils.java QAccel.java QAction.java QActionGroup.java QApplication.java QAsyncIO.java QAuServer.java QBig5Codec.java QBitmap.java QBoxLayout.java QBrush.java QBuffer.java QButton.java QButtonGroup.java QCanvas.java QCanvasEllipse.java QCanvasItem.java QCanvasLine.java QCanvasPixmap.java QCanvasPixmapArray.java QCanvasPolygon.java QCanvasPolygonalItem.java QCanvasRectangle.java QCanvasSprite.java QCanvasText.java QCanvasView.java QCheckListItem.java QChildEvent.java QClassInfo.java QClipboard.java QCloseEvent.java QColor.java QColorDialog.java QColorDrag.java QColorGroup.java QComboBox.java QCursor.java QCustomEvent.java QCustomMenuItem.java QDataPump.java QDataSink.java QDataSource.java QDataStream.java QDial.java QDialog.java QDir.java QDomAttr.java QDomCDATASection.java QDomCharacterData.java QDomComment.java QDomDocument.java QDomDocumentFragment.java QDomDocumentType.java QDomElement.java QDomEntity.java QDomEntityReference.java QDomImplementation.java QDomNamedNodeMap.java QDomNode.java QDomNotation.java QDomProcessingInstruction.java QDomText.java QDoubleValidator.java QDragEnterEvent.java QDragLeaveEvent.java QDragManager.java QDragMoveEvent.java QDragObject.java QDragResponseEvent.java QDropEvent.java QDropSite.java QEucJpCodec.java QEucKrCodec.java QEvent.java QFile.java QFileDialog.java QFileIconProvider.java QFileInfo.java QFilePreview.java QFocusData.java QFocusEvent.java QFont.java QFontDatabase.java QFontDialog.java QFontInfo.java QFontMetrics.java QFrame.java QGL.java QGLContext.java QGLFormat.java QGLWidget.java QGbkCodec.java QGrid.java QGridLayout.java QGroupBox.java QHBox.java QHBoxLayout.java QHButtonGroup.java QHGroupBox.java QHeader.java QHebrewCodec.java QHideEvent.java QIODevice.java QIODeviceInterface.java QIODeviceSource.java QIconDrag.java QIconDragItem.java QIconSet.java QIconView.java QIconViewItem.java QImage.java QImageConsumer.java QImageDecoder.java QImageDrag.java QImageFormat.java QImageFormatType.java QImageIO.java QImageTextKeyLang.java QInputDialog.java QIntValidator.java QJisCodec.java QJpUnicodeConv.java QKeyEvent.java QLCDNumber.java QLabel.java QLayout.java QLayoutItem.java QLayoutItemInterface.java QLineEdit.java QListBox.java QListBoxItem.java QListBoxPixmap.java QListBoxText.java QListView.java QListViewItem.java QMainWindow.java QMenuBar.java QMenuData.java QMenuDataInterface.java QMessageBox.java QMetaData.java QMetaEnum.java QMetaObject.java QMetaProperty.java QMimeSource.java QMimeSourceFactory.java QMimeSourceInterface.java QMouseEvent.java QMoveEvent.java QMovie.java QMultiLineEdit.java QNetworkOperation.java QObject.java QPaintDevice.java QPaintDeviceInterface.java QPaintEvent.java QPainter.java QPalette.java QPen.java QPicture.java QPixmap.java QPoint.java QPointArray.java QPolygonScanner.java QPopupMenu.java QPrintDialog.java QPrinter.java QProgressBar.java QProgressDialog.java QPushButton.java QRadioButton.java QRangeControl.java QRangeControlInterface.java QRect.java QRegion.java QResizeEvent.java QScrollBar.java QScrollView.java QSemiModal.java QSessionManager.java QShowEvent.java QSignal.java QSignalMapper.java QSimpleRichText.java QSize.java QSizeGrip.java QSizePolicy.java QSjisCodec.java QSlider.java QSound.java QSpacerItem.java QSpinBox.java QSplitter.java QStatusBar.java QStoredDrag.java QStyle.java QStyleSheet.java QStyleSheetItem.java QTab.java QTabBar.java QTabDialog.java QTabWidget.java QTable.java QTableItem.java QTableSelection.java QTextBrowser.java QTextCodec.java QTextDecoder.java QTextDrag.java QTextEncoder.java QTextIStream.java QTextOStream.java QTextStream.java QTextView.java QTimer.java QTimerEvent.java QToolBar.java QToolButton.java QToolTip.java QToolTipGroup.java QTranslator.java QTranslatorMessage.java QTsciiCodec.java QUriDrag.java QUrl.java QUrlInfo.java QUrlInterface.java QUrlOperator.java QUtf16Codec.java QUtf8Codec.java QVBox.java QVBoxLayout.java QVButtonGroup.java QVGroupBox.java QValidator.java QVariant.java QWMatrix.java QWhatsThis.java QWheelEvent.java QWidget.java QWidgetItem.java QWidgetStack.java QMenuItem.java QPaintDeviceMetrics.java QRegExp.java QCanvasSpline.java QCheckTableItem.java QComboTableItem.java QContextMenuEvent.java QDataBrowser.java QDataTable.java QDataView.java QDateEdit.java QDateTimeEdit.java QDesktopWidget.java QDockArea.java QDockWindow.java QEditorFactory.java QErrorMessage.java QGLColormap.java QGridView.java QIMEvent.java QLibrary.java QProcess.java QRegExpValidator.java QSettings.java QSql.java QSqlCursor.java QSqlDatabase.java QSqlDriver.java QSqlEditorFactory.java QSqlError.java QSqlField.java QSqlForm.java QSqlIndex.java QSqlPropertyMap.java QSqlQuery.java QSqlRecord.java QSqlResult.java QTabletEvent.java QTextEdit.java QTimeEdit.java QUuid.java QDateTimeEditBase.java QSqlQueryInterface.java QAccelSignals.java QActionGroupSignals.java QActionSignals.java QApplicationSignals.java QButtonGroupSignals.java QButtonSignals.java QCanvasSignals.java QComboBoxSignals.java QDataBrowserSignals.java QDataTableSignals.java QDateEditSignals.java QDateTimeEditSignals.java QDesktopWidgetSignals.java QDialSignals.java QDockWindowSignals.java QFileDialogSignals.java QGroupBoxSignals.java QHeaderSignals.java QIconViewSignals.java QLCDNumberSignals.java QLineEditSignals.java QListBoxSignals.java QListViewSignals.java QMainWindowSignals.java QMenuBarSignals.java QObjectSignals.java QPopupMenuSignals.java QProcessSignals.java QProgressDialogSignals.java QScrollBarSignals.java QScrollViewSignals.java QSignalMapperSignals.java QSignalSignals.java QSliderSignals.java QSpinBoxSignals.java QStatusBarSignals.java QTabBarSignals.java QTabDialogSignals.java QTabWidgetSignals.java QTableSignals.java QTextBrowserSignals.java QTextEditSignals.java QTimeEditSignals.java QTimerSignals.java QToolTipGroupSignals.java QUrlOperatorSignals.java QWidgetStackSignals.java QStyleOption.java QKeySequence.java QSqlFieldInfo.java QSqlRecordInfo.java QFtp.java QHostAddress.java QHttp.java QLocalFs.java QNetworkProtocol.java QObjectCleanupHandler.java QServerSocket.java QSocket.java QSocketDevice.java QSocketNotifier.java QFtpSignals.java QHttpSignals.java QNetworkProtocolSignals.java QSocketSignals.java QSocketNotifierSignals.java QGb18030Codec.java QSpinWidget.java QSpinWidgetSignals.java QSplashScreen.java QSplashScreenSignals.java QToolBox.java QToolBoxSignals.java QHttpHeader.java QHttpRequestHeader.java QEventLoop.java QEventLoopSignals.java QHttpResponseHeader.java QStyleFactory.java QCheckBox.java QWorkspace.java QWizard.java QSyntaxHighlighter.java QXmlContentHandler.java QXmlDeclHandler.java QXmlDTDHandler.java QXmlEntityResolver.java QXmlErrorHandler.java QXmlLexicalHandler.java QXmlNamespaceSupport.java QXmlSimpleReader.java Invocation.java qtjava.java QtSupport.java QXmlDefaultHandler.java WeakValueMap.java Qt.java QWizardSignals.java QWorkspaceSignals.java QXmlAttributes.java QXmlContentHandlerInterface.java QXmlDTDHandlerInterface.java QXmlEntityResolverInterface.java QXmlErrorHandlerInterface.java QXmlInputSource.java QXmlLexicalHandlerInterface.java QXmlLocator.java QXmlParseException.java QXmlReader.java QXmlDeclHandlerInterface.java
/bin/sh: line 6: -d: command not found
make[6]: *** [classnoinst.stamp] Error 127
make[6]: Leaving directory `/tmp/kdebindings-3.5.8/qtjava/javalib/org/kde/qt'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory `/tmp/kdebindings-3.5.8/qtjava/javalib/org/kde'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/tmp/kdebindings-3.5.8/qtjava/javalib/org'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/tmp/kdebindings-3.5.8/qtjava/javalib'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/kdebindings-3.5.8/qtjava'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/kdebindings-3.5.8'
make: *** [all] Error 2
[root@Vito:kdebindings]#
Lo riporto tutto... :D aiutatemi! grazie di tutto in anticipo....
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
nessuno in grado di darmi qualche dritta???Manco Dani??? :(
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
ho risolto....manca il pacchetto jdk :D..stò usando quello della current ora..
Dani
Desktop: gnome
Distribuzione: arch
Messaggio da Dani »
Mi sa che arts avresti dovuto compilarlo prima di tutti !
Io ho compilato prima arts, poi akode, poi kdelibs, quindi kdebase...
John-Cena ha scritto:ho risolto....manca il pacchetto jdk :D..stò usando quello della current ora..
Ma tutto questo casino per non installare i pacchetti della current????
Bei miei 18 anni, come ti invidio :p
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
ennesimo errore nella compilazione di kdebindings:
make[4]: Leaving directory `/tmp/kdebindings-3.5.8/kdejava/koala/kdejava'
make[4]: Entering directory `/tmp/kdebindings-3.5.8/kdejava/koala'
/bin/sh ../../libtool --silent --tag=CXX   --mode=link g++  -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wchar-subscripts -Wall -W -Wpointer-arith -DNDEBUG -DNO_DEBUG -O2 -O2 -march=i486 -mtune=i686 -Wformat-security -Wmissing-format-attribute -Wno-non-virtual-dtor -fno-exceptions -fno-check-new -fno-common  -L/usr/lib/qt/lib     -R /usr/lib -R /usr/lib -R /usr/lib/qt/lib  -o koala main.o ./kdejava/libkdejava.la -lkspell -lqtjava -lkparts -lkio -lXext -lX11
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQDomNodeList(JNIEnv_*, QDomNodeList*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQDate(JNIEnv_*, QDate*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::connect(JNIEnv_*, _jobject*, _jstring*, _jobject*, _jstring*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQTime(JNIEnv_*, _jobject*, QTime**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQByteArray(JNIEnv_*, _jbyteArray*, QMemArray<char>**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::slotForReceiver(JNIEnv_*, _jobject*, _jstring*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toIntPtr(JNIEnv_*, _jintArray*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::objectForQtKey(JNIEnv_*, void*, char const*, bool)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQWidgetList(JNIEnv_*, QWidgetList*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQStringToStringBuffer(JNIEnv_*, QString*, _jobject*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQObjectList(JNIEnv_*, QObjectList*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::allocatedInJavaWorld(JNIEnv_*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromCharString(JNIEnv_*, char*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::paintDevice(JNIEnv_*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQIntValueList(JNIEnv_*, QValueList<int>*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::setObjectForQtKey(JNIEnv_*, _jobject*, void*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQStringFromStringBuffer(JNIEnv_*, _jobject*, QString**)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQStrList(JNIEnv_*, QStrList*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toArgv(JNIEnv_*, _jobjectArray*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::setQt(JNIEnv_*, _jobject*, void*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQByteArray(JNIEnv_*, QMemArray<char>*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQStringList(JNIEnv_*, _jobjectArray*, QStringList**)'
./kdejava/.libs/libkdejava.so: undefined reference to `JavaSlot::javaToQtSlotName(JNIEnv_*, _jstring*, char const*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQCString(JNIEnv_*, _jstring*, QCString**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQString(JNIEnv_*, QString*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQDateTime(JNIEnv_*, _jobject*, QDateTime**)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::toShortPtr(JNIEnv_*, _jshortArray*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQRectList(JNIEnv_*, QMemArray<QRect>*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::mimeSource(JNIEnv_*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQDateTime(JNIEnv_*, QDateTime*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::emitJavaSignal(JNIEnv_*, _jobject*, _jstring*, _jobjectArray*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toUcharArray(JNIEnv_*, _jcharArray*, QMemArray<char>**)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::fromIntPtr(JNIEnv_*, int*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toStringArray(JNIEnv_*, _jobjectArray*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::setAllocatedInJavaWorld(JNIEnv_*, _jobject*, bool)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toCharString(JNIEnv_*, _jstring*, QCString**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQString(JNIEnv_*, _jstring*, QString**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQStrList(JNIEnv_*, _jobjectArray*, QStrList**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::arrayWithQStringList(JNIEnv_*, QStringList*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `JavaSlot::javaToQtSignalName(JNIEnv_*, _jstring*, QMetaObject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::disconnect(JNIEnv_*, _jobject*, _jstring*, _jobject*, _jstring*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQChar(JNIEnv_*, QChar*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::toDoublePtr(JNIEnv_*, _jdoubleArray*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::getQt(JNIEnv_*, _jobject*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::registerJVM(JNIEnv_*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toBooleanPtr(JNIEnv_*, _jbooleanArray*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQCString(JNIEnv_*, QCString*)'
./kdejava/.libs/libkdejava.so: undefined reference to `JavaSlot::JavaSlot(JNIEnv_*, _jobject*, _jstring*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQListViewItemList(JNIEnv_*, QListViewItemIterator*, _jobject*)'
/usr/lib/libqtjava.so: undefined reference to `QtSupport::arrayWithQCanvasItemList(JNIEnv_*, QCanvasItemList*, _jobject*)'
/usr/lib/libqtjava.so: undefined reference to `JavaSlot::createJavaSlot(JNIEnv_*, _jobject*, _jstring*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQChar(JNIEnv_*, unsigned short, QChar**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQCStringToStringBuffer(JNIEnv_*, QCString*, _jobject*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQDate(JNIEnv_*, _jobject*, QDate**)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::fromQTime(JNIEnv_*, QTime*)'
./kdejava/.libs/libkdejava.so: undefined reference to `QtSupport::toQIntValueList(JNIEnv_*, _jintArray*, QValueList<int>**)'
collect2: ld returned 1 exit status
make[4]: *** [koala] Error 1
make[4]: Leaving directory `/tmp/kdebindings-3.5.8/kdejava/koala'
make[3]: Leaving directory `/tmp/kdebindings-3.5.8/kdejava/koala'
make[2]: Leaving directory `/tmp/kdebindings-3.5.8/kdejava'
qualcuno sa darmi qualche consiglio????
Ma compili un pacchetto alla volta od usi KDE.SlackBuild?
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
conraid ha scritto:Ma compili un pacchetto alla volta od usi KDE.SlackBuild?
compilo un pacchetto alla volta...fino ad ora ho compilatoed installato tutto...solo kdebindings mi da questo problema...
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
causa mancanza di tempo installo direttamente quelli della current :roll: hihihihhi
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
il mio dilemma ora è capire come mai mi dava quel problema mentre compilavo....sapreste aiutarmi? :oops: (scusate il doppio post)
