vlc -v --reset-config --reset-plugins-cache -lModeratore: Staff
[femachine@fire_eater-~]# vlc -v --reset-config --reset-plugins-cache -l
VLC media player 0.8.6g Janus
[00000001] main private warning: cannot load module `/usr/lib/vlc/gui/libwxwidgets_plugin.so' (libvcdinfo.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/misc/libnotify_plugin.so' (libnotify.so.1: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access_output/libaccess_output_shout_plugin.so' (libshout.so.3: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access_output/libaccess_output_http_plugin.so' (libavahi-common.so.3: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/codec/libtwolame_plugin.so' (libtwolame.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/codec/libquicktime_plugin.so' (/usr/lib/vlc/codec/libquicktime_plugin.so: undefined symbol: NewHandleClear)
[00000001] main private warning: cannot load module `/usr/lib/vlc/codec/liblibmpeg2_plugin.so' (libmpeg2.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/codec/libspeex_plugin.so' (libspeex.so.1: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/demux/libmod_plugin.so' (libmodplug.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/demux/libmkv_plugin.so' (libmatroska.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access/libaccess_dv_plugin.so' (librom1394.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access/libdvdnav_plugin.so' (libdvdnav.so.4: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access/libvcdx_plugin.so' (libvcdinfo.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/access/libdvdread_plugin.so' (libdvdread.so.4: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/visualization/libxosd_plugin.so' (libxosd.so.2: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/visualization/libgoom_plugin.so' (libgoom2.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/video_output/libggi_plugin.so' (libggi.so.2: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/services_discovery/libdaap_plugin.so' (libopendaap.so.0: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/services_discovery/libbonjour_plugin.so' (libavahi-common.so.3: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/services_discovery/libupnp_intel_plugin.so' (libupnp.so.2: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/audio_output/libportaudio_plugin.so' (libportaudio.so.2: cannot open shared object file: No such file or directory)
[00000001] main private warning: cannot load module `/usr/lib/vlc/audio_output/libjack_plugin.so' (libjack.so.0: cannot open shared object file: No such file or directory)
main main program
help Help options
live555 RTP/RTSP/SDP demuxer (using Live555)
live555 RTSP/RTP access and demux
mux_ts TS muxer (libdvbpsi)
ffmpeg FFmpeg audio/video decoder/encoder ((MS)MPEG4,SVQ1,H263,WMV,WMA)
ffmpeg FFmpeg chroma conversion
[00000001] main private warning: cannot load module `/usr/lib/vlc/codec/libquicktime_plugin.so' (/usr/lib/vlc/codec/libquicktime_plugin.so: undefined symbol: NewHandleClear)Quest' errore l'ha data sempre dalle prime versioni del pacchetto VLC apparse su Slacky. Libquicktime è una delle dipendenze da eliminare.Fire_eater ha scritto:OK. funziona![]()
Però con questo comando vlc -v --reset-config --reset-plugins-cache -l mi da ancora questo warning.
aLvArO ha scritto:ma quindi va sistemata anche la lista delle dipendenze richieste da vlc.
chi scarica il pacchetto scarica le dipendenze che sono elencate la sotto e ovviamente non funziona.
ma poi come mai sono necessari pmount, xmms, lua ?
Allora puoi usare l'ottimo tracepkg di absintheaLvArO ha scritto:con le dipendenze ho un brutto rapporto a volte, nel senso che una volta installate ho sempre paura a rimuoverle per evitare che siano in comune con altri pacchetti
Domanda, ma wxGTK non è inglobato in wxwidgets?gohanz ha scritto:Se lanciare VLC da shell con questo comando, avete messaggi di errore? Forse è il caso di ricompilare VLC con le wx 2.8?![]()
*** glibc detected *** vlc: free(): invalid pointer: 0x08a6fe70 ***
======= Backtrace: =========
/lib/libc.so.6[0xb79aa8c4]
/lib/libc.so.6(cfree+0x90)[0xb79ae370]
/usr/lib/libglib-2.0.so.0(g_free+0x31)[0xb4cad431]
/usr/lib/vlc/gui/libwxwidgets_plugin.so[0xb555030c]
======= Memory map: ========
08048000-08658000 r-xp 00000000 03:01 1966502 /usr/bin/vlc
08658000-08674000 rw-p 0060f000 03:01 1966502 /usr/bin/vlc
08674000-08a93000 rw-p 08674000 00:00 0 [heap]
b3400000-b3421000 rw-p b3400000 00:00 0
b3421000-b3500000 ---p b3421000 00:00 0
b3523000-b3527000 r-xp 00000000 03:01 2770960 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3527000-b3528000 rw-p 00003000 03:01 2770960 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3529000-b362d000 rw-p b3529000 00:00 0
b362d000-b36bf000 r--p 00000000 03:01 2829055 /usr/share/fonts/TTF/DejaVuSans.ttf
b36bf000-b36c1000 r-xp 00000000 03:01 2615962 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b36c1000-b36c2000 rw-p 00001000 03:01 2615962 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b36c2000-b36c5000 rw-s 00000000 00:08 3768327 /SYSV00000000 (deleted)
b36c5000-b3725000 rw-s 00000000 00:08 3735558 /SYSV00000000 (deleted)
b3725000-b3785000 rw-s 00000000 00:08 3702789 /SYSV00000000 (deleted)
b3785000-b37ac000 r-xp 00000000 03:01 1851730 /usr/lib/libkdefx.so.4.2.0
b37ac000-b37ad000 rw-p 00027000 03:01 1851730 /usr/lib/libkdefx.so.4.2.0
b37ad000-b37cb000 r-xp 00000000 03:01 2550531 /usr/lib/kde3/plugins/styles/plastik.so
b37cb000-b37cc000 rw-p 0001e000 03:01 2550531 /usr/lib/kde3/plugins/styles/plastik.so
b37cc000-b37dc000 r--s 00000000 03:01 1875988 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86.cache-2
b37dc000-b37e6000 r--s 00000000 03:01 1875991 /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86.cache-2
b37e6000-b3831000 r-xp 00000000 03:01 1853702 /usr/lib/libXt.so.6.0.0
b3831000-b3835000 rw-p 0004a000 03:01 1853702 /usr/lib/libXt.so.6.0.0
b3835000-b3868000 r-xp 00000000 03:01 1852935 /usr/lib/liblcms.so.1.0.16
b3868000-b386a000 rw-p 00032000 03:01 1852935 /usr/lib/liblcms.so.1.0.16
b386a000-b386c000 rw-p b386a000 00:00 0
b386c000-b387d000 r-xp 00000000 03:01 1853655 /usr/lib/libXft.so.2.1.2
b387d000-b387e000 rw-p 00010000 03:01 1853655 /usr/lib/libXft.so.2.1.2
b387e000-b3892000 r-xp 00000000 03:01 1853667 /usr/lib/libXmu.so.6.2.0
b3892000-b3893000 rw-p 00014000 03:01 1853667 /usr/lib/libXmu.so.6.2.0
b3893000-b3907000 r-xp 00000000 03:01 1853874 /usr/lib/libGL.so.1.2
b3907000-b3909000 rw-p 00073000 03:01 1853874 /usr/lib/libGL.so.1.2
b3909000-b390d000 rw-p b3909000 00:00 0
b390d000-b396b000 r-xp 00000000 03:01 1853061 /usr/lib/libmng.so.1.0.0
b396b000-b396e000 rw-p 0005d000 03:01 1853061 /usr/lib/libmng.so.1.0.0
b396e000-b3982000 r-xp 00000000 03:01 1853575 /usr/lib/libICE.so.6.3.0
b3982000-b3984000 rw-p 00013000 03:01 1853575 /usr/lib/libICE.so.6.3.0
b3984000-b3985000 rw-p b3984000 00:00 0
b3985000-b398c000 r-xp 00000000 03:01 1853579 /usr/lib/libSM.so.6.0.0
b398c000-b398d000 rw-p 00006000 03:01 1853579 /usr/lib/libSM.so.6.0.0
b398d000-b3fef000 r-xp 00000000 03:01 2794366 /usr/lib/qt-3.3.8b/lib/libqt-mt.so.3.3.8
b3fef000-b402e000 rw-p 00662000 03:01 2794366 /usr/lib/qt-3.3.8b/lib/libqt-mt.so.3.3.8
b402e000-b4032000 rw-p b402e000 00:00 0
b4032000-b4038000 r-xp 00000000 03:01 2770972 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-xpm.so
b4038000-b4039000 rw-p 00005000 03:01 2770972 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-xpm.so
b4039000-b404f000 r--s 00000000 03:01 1875994 /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-x86.cache-2
b404f000-b4054000 r--s 00000000 03:01 1878400 /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-x86.cache-2
b4054000-b4073000 r-xp 00000000 03:01 2771551 /usr/lib/gtk-2.0/2.10.0/engines/libqtengine.so
b4073000-b4074000 rw-p 0001f000 03:01 2771551 /usr/lib/gtk-2.0/2.10.0/engines/libqtengine.so
b4074000-b4075000 r--p 00000000 03:01 2745944 /usr/lib/locale/en_US/LC_NUMERIC
b4075000-b4076000 r--p 00000000 03:01 2753505 /usr/lib/locale/en_US/LC_TIME
b4076000-b4077000 r--p 00000000 03:01 2753501 /usr/lib/locale/en_US/LC_MONETARY
b4077000-b4078000 r--p 00000000 03:01 2753915 /usr/lib/locale/en_US/LC_PAPER
b4078000-b4079000 r--p 00000000 03:01 2745984 /usr/lib/locale/en_US/LC_NAME
b4079000-b407a000 r--p 00000000 03:01 2753503 /usr/lib/locale/en_US/LC_ADDRESS
b407a000-b407b000 ---p b407a000 00:00 0
b407b000-b487a000 rwxp b407b000 00:00 0
b487a000-b487e000 r-xp 00000000 03:01 1853630 /usr/lib/libXdmcp.so.6.0.0
b487e000-b487f000 rw-p 00003000 03:01 1853630 /usr/lib/libXdmcp.so.6.0.0
b487f000-b48b9000 r-xp 00000000 03:01 1853082 /usr/lib/libpng12.so.0.1.2.27
b48b9000-b48ba000 rw-p 0003a000 03:01 1853082 /usr/lib/libpng12.so.0.1.2.27
b48ba000-b4924000 r-xp 00000000 03:01 2236499 /usr/lib/libfreetype.so.6.3.16
b4924000-b4928000 rw-p 00069000 03:01 2236499 /usr/lib/libfreetype.so.6.3.16
b4928000-b494e000 r-xp 00000000 03:01 1853229 /usr/lib/libpangoft2-1.0.so.0.2000.0
b494e000-b494f000 rw-p 00026000 03:01 1853229 /usr/lib/libpangoft2-1.0.so.0.2000.0
b494f000-b4951000 r-xp 00000000 03:01 1853598 /usr/lib/libXau.so.6.0.0
b4951000-b4952000 rw-p 00001000 03:01 1853598 /usr/lib/libXau.so.6.0.0
b4952000-b4968000 r-xp 00000000 03:01 1853785 /usr/lib/libxcb.so.1.0.0
b4968000-b4969000 rw-p 00016000 03:01 1853785 /usr/lib/libxcb.so.1.0.0
b4969000-b496a000 r-xp 00000000 03:01 1853793 /usr/lib/libxcb-xlib.so.0.0.0
b496a000-b496b000 rw-p 00000000 03:01 1853793 /usr/lib/libxcb-xlib.so.0.0.0
b496b000-b4973000 r-xp 00000000 03:01 1853622 /usr/lib/libXcursor.so.1.0.2
b4973000-b4974000 rw-p 00007000 03:01 1853622 /usr/lib/libXcursor.so.1.0.2
b4974000-b497b000 r-xp 00000000 03:01 1853658 /usr/lib/libXi.so.6.0.0
b497b000-b497c000 rw-p 00006000 03:01 1853658 /usr/lib/libXi.so.6.0.0
b497c000-b499f000 r-xp 00000000 03:01 1853567 /usr/lib/libfontconfig.so.1.2.0
b499f000-b49a7000 rw-p 00022000 03:01 1853567 /usr/lib/libfontconfig.so.1.2.0
b49a7000-b4a1b000 r-xp 00000000 03:01 1852702 /usr/lib/libcairo.so.2.11.7
b4a1b000-b4a1d000 rw-p 00073000 03:01 1852702 /usr/lib/libcairo.so.2.11.7
b4a1d000-b4a21000 r-xp 00000000 03:01 1853642 /usr/lib/libXfixes.so.3.1.0
b4a21000-b4a22000 rw-p 00003000 03:01 1853642 /usr/lib/libXfixes.so.3.1.0
b4a22000-b4a2a000 r-xp 00000000 03:01 1853232 /usr/lib/libpangocairo-1.0.so.0.2000.0
b4a2a000-b4a2b000 rw-p 00008000 03:01 1853232 /usr/lib/libpangocairo-1.0.so.0.2000.0
b4a2b000-b4a89000 r-xp 00000000 03:01 2236509 /usr/lib/libvga.so.1.9.25
b4a89000-b4a8f000 rw-p 0005d000 03:01 2236509 /usr/lib/libvga.so.1.9.25
b4a8f000-b4aa7000 rw-p b4a8f000 00:00 0
b4aa7000-b4aae000 r-xp 00000000 03:01 1853694 /usr/lib/libXrender.so.1.3.0
b4aae000-b4aaf000 rw-p 00006000 03:01 1853694 /usr/lib/libXrender.so.1.3.0
b4aaf000-b4ab4000 r-xp 00000000 03:01 1853691 /usr/lib/libXrandr.so.2.1.0
b4ab4000-b4ab5000 rw-p 00004000 03:01 1853691 /usr/lib/libXrandr.so.2.1.0
b4ab5000-b4ac2000 r-xp 00000000 03:01 1853638 /usr/lib/libXext.so.6.4.0
b4ac2000-b4ac3000 rw-p 0000c000 03:01 1853638 /usr/lib/libXext.so.6.4.0
b4ac3000-b4ba6000 r-xp 00000000 03:01 1853582 /usr/lib/libX11.so.6.2.0
b4ba6000-b4baa000 rw-p 000e2000 03:01 1853582 /usr/lib/libX11.so.6.2.0
b4baa000-b4bc8000 r-xp 00000000 03:01 2236505 /usr/lib/libexpat.so.1.5.2
b4bc8000-b4bca000 rw-p 0001d000 03:01 2236505 /usr/lib/libexpat.so.1.5.2
b4bca000-b4c1c000 r-xp 00000000 03:01 2236527 /usr/lib/libtiff.so.3.8.2
b4c1c000-b4c1e000 rw-p 00052000 03:01 2236527 /usr/lib/libtiff.so.3.8.2
b4c1e000-b4c3d000 r-xp 00000000 03:01 2236536 /usr/lib/libjpeg.so.62.0.0
b4c3d000-b4c3e000 rw-p 0001e000 03:01 2236536 /usr/lib/libjpeg.so.62.0.0
b4c3e000-b4c78000 r-xp 00000000 03:01 1853081 /usr/lib/libpng.so.3.1.2.27
b4c78000-b4c79000 rw-p 0003a000 03:01 1853081 /usr/lib/libpng.so.3.1.2.27
b4c79000-b4d34000 r-xp 00000000 03:01 2236528 /usr/lib/libglib-2.0.so.0.1400.6
b4d34000-b4d35000 rw-p 000bb000 03:01 2236528 /usr/lib/libglib-2.0.so.0.1400.6
b4d35000-b4d6d000 r-xp 00000000 03:01 2236511 /usr/lib/libgobject-2.0.so.0.1400.6
b4d6d000-b4d6e000 rw-p 00038000 03:01 2236511 /usr/lib/libgobject-2.0.so.0.1400.6
b4d6e000-b4da8000 r-xp 00000000 03:01 1853233 /usr/lib/libpango-1.0.so.0.2000.0
b4da8000-b4daa000 rw-p 00039000 03:01 1853233 /usr/lib/libpango-1.0.so.0.2000.0
b4daa000-b4dc0000 r-xp 00000000 03:01 1852879 /usr/lib/libgdk_pixbuf-2.0.so.0.1200.9
b4dc0000-b4dc1000 rw-p 00016000 03:01 1852879 /usr/lib/libgdk_pixbuf-2.0.so.0.1200.9
b4dc1000-b4e40000 r-xp 00000000 03:01 1852878 /usr/lib/libgdk-x11-2.0.so.0.1200.9
b4e40000-b4e43000 rw-p 0007e000 03:01 1852878 /usr/lib/libgdk-x11-2.0.so.0.1200.9
b4e43000-b51a2000 r-xp 00000000 03:01 1852882 /usr/lib/libgtk-x11-2.0.so.0.1200.9
b51a2000-b51a8000 rw-p 0035e000 03:01 1852882 /usr/lib/libgtk-x11-2.0.so.0.1200.9
b51a8000-b51a9000 rw-p b51a8000 00:00 0
b51a9000-b520f000 r-xp 00000000 03:01 1853297 /usr/lib/libSDL-1.2.so.0.11.2
b520f000-b5211000 rw-p 00066000 03:01 1853297 /usr/lib/libSDL-1.2.so.0.11.2
b5211000-b525e000 rw-p b5211000 00:00 0
b525e000-b5287000 r-xp 00000000 03:01 1854461 /usr/lib/libvcdinfo.so.0.2.0
b5287000-b5288000 rw-p 00028000 03:01 1854461 /usr/lib/libvcdinfo.so.0.2.0
b5288000-b5289000 rw-p b5288000 00:00 0
b5289000-b575e000 r-xp 00000000 03:01 2974203 /usr/lib/vlc/gui/libwxwidgets_plugin.so
b575e000-b5776000 rw-p 004d5000 03:01 2974203 /usr/lib/vlc/gui/libwxwidgets_plugin.so
b5776000-b578c000 rw-p b5776000 00:00 0
b578c000-b578d000 ---p b578c000 00:00 0
b578d000-b5f8c000 rwxp b578d000 00:00 0
b5f8c000-b5f8d000 ---p b5f8c000 00:00 0
b5f8d000-b678c000 rwxp b5f8d000 00:00 0
b678c000-b6791000 r-xp 00000000 03:01 2974130 /usr/lib/vlc/control/libhotkeys_plugin.so
b6791000-b6792000 rw-p 00004000 03:01 2974130 /usr/lib/vlc/control/libhotkeys_plugin.so
b6792000-b6793000 ---p b6792000 00:00 0
b6793000-b6f92000 rwxp b6793000 00:00 0
b6f92000-b6f93000 ---p b6f92000 00:00 0
b6f93000-b7792000 rwxp b6f93000 00:00 0
b7792000-b7851000 r-xp 00000000 03:01 2236510 /usr/lib/libasound.so.2.0.0
b7851000-b7856000 rw-p 000be000 03:01 2236510 /usr/lib/libasound.so.2.0.0
b7856000-b7857000 r--p 00000000 03:01 2754029 /usr/lib/locale/en_US/LC_TELEPHONE
b7857000-b7859000 r-xp 00000000 03:01 1853626 /usr/lib/libXdamage.so.1.1.0
b7859000-b785a000 rw-p 00001000 03:01 1853626 /usr/lib/libXdamage.so.1.1.0
b785a000-b785e000 r-xp 00000000 03:01 1853730 /usr/lib/libXxf86vm.so.1.0.0
b785e000-b785f000 rw-p 00003000 03:01 1853730 /usr/lib/libXxf86vm.so.1.0.0
b785f000-b7876000 r-xp 00000000 03:01 1852693 /usr/lib/libatk-1.0.so.0.2209.1
b7876000-b7878000 rw-p 00017000 03:01 1852693 /usr/lib/libatk-1.0.so.0.2209.1
b7878000-b7891000 r-xp 00000000 03:01 1852990 /usr/lib/libcdio.so.7.1.1
b7891000-b7892000 rw-p 00018000 03:01 1852990 /usr/lib/libcdio.so.7.1.1
b7892000-b7896000 rw-p b7892000 00:00 0
b7896000-b789c000 r-xp 00000000 03:01 1852984 /usr/lib/libcdio_cdda.so.0.0.3
b789c000-b789d000 rw-p 00005000 03:01 1852984 /usr/lib/libcdio_cdda.so.0.0.3
b789d000-b789e000 r--p 00000000 03:01 2753916 /usr/lib/locale/en_US/LC_MEASUREMENT
b789e000-b78a0000 r-xp 00000000 03:01 1853619 /usr/lib/libXcomposite.so.1.0.0
b78a0000-b78a1000 rw-p 00001000 03:01 1853619 /usr/lib/libXcomposite.so.1.0.0
b78a1000-b78a3000 r-xp 00000000 03:01 1853663 /usr/lib/libXinerama.so.1.0.0
b78a3000-b78a4000 rw-p 00001000 03:01 1853663 /usr/lib/libXinerama.so.1.0.0
b78a4000-b78a7000 r-xp 00000000 03:01 2236517 /usr/lib/libgthread-2.0.so.0.1400.6
b78a7000-b78a8000 rw-p 00003000 03:01 2236517 /usr/lib/libgthread-2.0.so.0.1400.6
b78a8000-b78aa000 r-xp 00000000 03:01 2236512 /usr/lib/libgmodule-2.0.so.0.1400.6
b78aa000-b78ab000 rw-p 00002000 03:01 2236512 /usr/lib/libgmodule-2.0.so.0.1400.6
b78ab000-b78b6000 r-xp 00000000 03:01 1852985 /usr/lib/libiso9660.so.5.1.0
b78b6000-b78b7000 rw-p 0000a000 03:01 1852985 /usr/lib/libiso9660.so.5.1.0
b78b7000-b78b8000 r-xp 00000000 03:01 2935689 /usr/lib/vlc/misc/libscreensaver_plugin.so
b78b8000-b78b9000 rw-p 00000000 03:01 2935689 /usr/lib/vlc/misc/libscreensaver_plugin.so
b78b9000-b78be000 r-xp 00000000 03:01 2974305 /usr/lib/vlc/audio_output/libalsa_plugin.so
b78be000-b78bf000 rw-p 00004000 03:01 2974305 /usr/lib/vlc/audio_output/libalsa_plugin.so
b78bf000-b78c8000 r-xp 00000000 03:01 1687631 /lib/libnss_files-2.7.so
b78c8000-b78ca000 rw-p 00008000 03:01 1687631 /lib/libnss_files-2.7.so
b78ca000-b78d2000 r-xp 00000000 03:01 1687633 /lib/libnss_nis-2.7.so
b78d2000-b78d4000 rw-p 00007000 03:01 1687633 /lib/libnss_nis-2.7.so
b78d4000-b78db000 r-xp 00000000 03:01 1687629 /lib/libnss_compat-2.7.so
b78db000-b78dd000 rw-p 00006000 03:01 1687629 /lib/libnss_compat-2.7.so
b78dd000-b78de000 r--p 00000000 03:01 2753502 /usr/lib/locale/en_US/LC_IDENTIFICATION
b78de000-b78e4000 r-xp 00000000 03:01 1852992 /usr/lib/libcdio_paranoia.so.0.0.2
b78e4000-b78e5000 rw-p 00005000 03:01 1852992 /usr/lib/libcdio_paranoia.so.0.0.2
b78e5000-b78f2000 r-xp 00000000 03:01 1852978 /usr/lib/libcddb.so.2.2.3
b78f2000-b78f3000 rw-p 0000d000 03:01 1852978 /usr/lib/libcddb.so.2.2.3
b78f3000-b78fe000 r-xp 00000000 03:01 2974285 /usr/lib/vlc/access/libcddax_plugin.so
b78fe000-b78ff000 rw-p 0000b000 03:01 2974285 /usr/lib/vlc/access/libcddax_plugin.so
b78ff000-b7935000 r--p 00000000 03:01 2745951 /usr/lib/locale/en_US/LC_CTYPE
b7935000-b7937000 rw-p b7935000 00:00 0
b7937000-b793d000 r-xp 00000000 03:01 2236503 /usr/lib/libusb-0.1.so.4.4.4
b793d000-b793f000 rw-p 00005000 03:01 2236503 /usr/lib/libusb-0.1.so.4.4.4
b793f000-b7a85000 r-xp 00000000 03:01 1687622 /lib/libc-2.7.so
b7a85000-b7a86000 r--p 00146000 03:01 1687622 /lib/libc-2.7.so
b7a86000-b7a88000 rw-p 00147000 03:01 1687622 /lib/libc-2.7.so
b7a88000-b7a8c000 rw-p b7a88000 00:00 0
b7a8c000-b7a96000 r-xp 00000000 03:01 2236514 /usr/lib/libgcc_s.so.1
b7a96000-b7a97000 rw-p 00009000 03:01 2236514 /usr/lib/libgcc_s.so.1
b7a97000-b7abb000 r-xp 00000000 03:01 1687626 /lib/libm-2.7.so
b7abb000-b7abd000 rw-p 00023000 03:01 1687626 /lib/libm-2.7.so
b7abd000-b7b98000 r-xp 00000000 03:01 2238598 /usr/lib/libstdc++.so.6.0.9
b7b98000-b7b9c000 r--p 000da000 03:01 2238598 /usr/lib/libstdc++.so.6.0.9
b7b9c000-b7b9d000 rw-p 000de000 03:01 2238598 /usr/lib/libstdc++.so.6.0.9
b7b9d000-b7ba3000 rw-p b7b9d000 00:00 0
b7ba3000-b7ba7000 r-xp 00000000 03:01 1853077 /usr/lib/libogg.so.0.5.3
b7ba7000-b7ba8000 rw-p 00003000 03:01 1853077 /usr/lib/libogg.so.0.5.3
b7ba8000-b7bef000 r-xp 00000000 03:01 1853094 /usr/lib/libtheora.so.0.3.2
b7bef000-b7bf1000 rw-p 00046000 03:01 1853094 /usr/lib/libtheora.so.0.3.2
b7bf1000-b7c2e000 r-xp 00000000 03:01 1854148 /usr/lib/libmp3lame.so.0.0.0
b7c2e000-b7c30000 rw-p 0003c000 03:01 1854148 /usr/lib/libmp3lame.so.0.0.0
b7c30000-b7c61000 rw-p b7c30000 00:00 0
b7c61000-b7c71000 r-xp 00000000 03:01 1854122 /usr/lib/libfaac.so.0.0.0
b7c71000-b7c74000 rw-p 0000f000 03:01 1854122 /usr/lib/libfaac.so.0.0.0
b7c74000-b7c8f000 r-xp 00000000 03:01 1853135 /usr/lib/libvorbis.so.0.4.0
b7c8f000-b7c9d000 rw-p 0001a000 03:01 1853135 /usr/lib/libvorbis.so.0.4.0
b7c9d000-b7ca9000 r-xp 00000000 03:01 1853130 /usr/lib/libvorbisenc.so.2.0.3
b7ca9000-b7d97000 rw-p 0000c000 03:01 1853130 /usr/lib/libvorbisenc.so.2.0.3
b7d97000-b7daa000 r-xp 00000000 03:01 2236497 /usr/lib/libz.so.1.2.3
b7daa000-b7dab000 rw-p 00012000 03:01 2236497 /usr/lib/libz.so.1.2.3
b7dab000-b7de3000 r-xp 00000000 03:01 1854127 /usr/lib/libfaad.so.0.0.0
b7de3000-b7de6000 rw-p 00038000 03:01 1854127 /usr/lib/libfaad.so.0.0.0
b7de6000-b7e83000 r-xp 00000000 03:01 1854483 /usr/lib/libxvidcore.so.4.1
b7e83000-b7e84000 rw-p 0009d000 03:01 1854483 /usr/lib/libxvidcore.so.4.1
b7e84000-b7ef8000 rw-p b7e84000 00:00 0
b7ef8000-b7f03000 r-xp 00000000 03:01 1854182 /usr/lib/libdvbpsi.so.5.0.0
b7f03000-b7f04000 rw-p 0000a000 03:01 1854182 /usr/lib/libdvbpsi.so.5.0.0
b7f04000-b7f06000 r-xp 00000000 03:01 1687625 /lib/libdl-2.7.so
b7f06000-b7f08000 rw-p 00001000 03:01 1687625 /lib/libdl-2.7.so
b7f08000-b7f1b000 r-xp 00000000 03:01 1687636 /lib/libpthread-2.7.so
b7f1b000-b7f1d000 rw-p 00013000 03:01 1687636 /lib/libpthread-2.7.so
b7f1d000-b7f1f000 rw-p b7f1d000 00:00 0
b7f1f000-b7f26000 r-xp 00000000 03:01 1687638 /lib/librt-2.7.so
b7f26000-b7f28000 rw-p 00006000 03:01 1687638 /lib/librt-2.7.so
b7f28000-b7f5c000 r-xp 00000000 03:01 1852723 /usr/lib/libdbus-1.so.3.4.0
b7f5c000-b7f5e000 rw-p 00033000 03:01 1852723 /usr/lib/libdbus-1.so.3.4.0
b7f5e000-b7f6b000 r-xp 00000000 03:01 1852891 /usr/lib/libhal.so.1.0.0
b7f6b000-b7f6c000 rw-p 0000c000 03:01 1852891 /usr/lib/libhal.so.1.0.0
b7f6c000-b7f6d000 rw-p b7f6c000 00:00 0
b7f6d000-b7f6e000 r-xp 00000000 03:01 2935683 /usr/lib/vlc/misc/libmemcpy_plugin.so
b7f6e000-b7f6f000 rw-p 00000000 03:01 2935683 /usr/lib/vlc/misc/libmemcpy_plugin.so
b7f6f000-b7f72000 r-xp 00000000 03:01 2974311 /usr/lib/vlc/audio_output/liboss_plugin.so
b7f72000-b7f73000 rw-p 00002000 03:01 2974311 /usr/lib/vlc/audio_output/liboss_plugin.so
b7f73000-b7f87000 r-xp 00000000 03:01 1687628 /lib/libnsl-2.7.so
b7f87000-b7f89000 rw-p 00013000 03:01 1687628 /lib/libnsl-2.7.so
b7f89000-b7f8b000 rw-p b7f89000 00:00 0
b7f8b000-b7f8c000 r-xp 00000000 03:01 2245677 /usr/lib/gconv/ISO8859-1.so
b7f8c000-b7f8e000 rw-p 00000000 03:01 2245677 /usr/lib/gconv/ISO8859-1.so
b7f8e000-b7f8f000 r--p 00000000 03:01 2745982 /usr/lib/locale/en_US/LC_MESSAGES/SYS_LC_MESSAGES
b7f8f000-b7fab000 r-xp 00000000 03:01 1687664 /lib/ld-2.7.so
b7fab000-b7fad000 rw-p 0001b000 03:01 1687664 /lib/ld-2.7.so
bfddd000-bfdf0000 rwxp bffeb000 00:00 0 [stack]
bfdf0000-bfdf2000 rw-p bfffe000 00:00 0
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
Aborted
export MALLOC_CHECK_=0 Codice: Seleziona tutto
/etc/profile.d/glibc.sh Codice: Seleziona tutto
Segmentation fault
$ firefox
/usr/lib/firefox-2.0.0.14/run-mozilla.sh: line 131: 3461 Segmentation fault "$prog" ${1+"$@"}
